Electric contact mercury thermometer constant temperature control circuit 3b
Source: InternetPublisher:闪电杰克 Keywords: Thermostatic control circuit BSP alarm Updated: 2021/02/20
These two circuits are similar. Figure
Ll-45 (a) is equipped with an over-temperature alarm . The setting value of temperature sensor KP2 should be higher than KP. The setting value is 1~2℃ higher.
For example, if 100 eggs are hatched at a time, 500-600W electric heater wire can be used (straightened and evenly installed on
the bottom of the incubator).
Figure 11-45 (b) shows the temperature control circuit of the DF-500 electric incubator with a capacity of 500 eggs. The shape of the incubator box
is 1000mm high, 970mm wide, 680mm deep, and the insulation layer is 30mm thick. A 75-150W soldering iron core is used
as an electric heater. An instrument fan is installed at the air inlet in the box so that fresh air can be continuously sucked in when the fan is running. The soldering iron
core is fixed in front of the fan blades and directly in front of the fan. Place a plate of clean water somewhere to maintain a certain humidity.
- Analysis of the working principle of car garage door lights
- How to remotely control devices using ESP8266 and LPC2148
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Peripheral circuit of automotive motor controller power supply chip
- Perform surgery on the speaker protection circuit
- Simple three-phase motor phase loss protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- Night dog barking anti-theft reminder circuit
- Water supply reminder after water outage
- "Watchdog" anti-theft alarm circuit
- Bone hyperplasia treatment circuit
- Pulse therapy circuit
- soil content measurement circuit
- Straw returning to field crusher circuit
- DC ammeter
- Broadband high frequency power amplifier circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Differential Amplifier Circuit
- color discrimination circuit
- Color display circuit
