One of the reed switch liquid level automatic control circuits (fill-in type)
Source: InternetPublisher:qoistoochee128 Keywords: BSP liquid level control control circuit Updated: 2021/10/23
It adopts reed switch control and can be used for level control of non-conductive liquids . It
controls the action of the reed switch through the magnetic ring or magnetic head according to the rise and fall of the liquid level, and then controls the starting and stopping of the pump. Figure 11-10 is a flooded liquid level
automatic control circuit. If it is a withdrawable liquid level control , just put the reed switch KR at the upper limit and KR at the lower limit
, and the control circuit remains unchanged. The same below.
In the figure, R and C are spark suppression circuits to protect the reed switch contacts. Reed switch KRi uses JAG4-H (normally open type),
<R2 uses JAG4-2 (conversion type).
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to Make a Simple Chicken Incubator
- A simple door handle touch alarm circuit
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Working principle of one Xipu STR soft starter controlling two motors
- Squirrel cage asynchronous motor reverse braking control circuit
- Design and production of radio remote control fan stepless speed regulator
- Audio interface protection circuit
- Password type motorcycle anti-theft device
- Simple disconnection burglar alarm
- Particle clogging alarm circuit of wheat seeder
- Greenhouse temperature control circuit
- Double detuned loop frequency discriminator circuit
- ring amplitude modulation circuit
- Voltage series negative feedback amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Three primary color display circuit
- Guest arrival signal recognition circuit
- Small current generator circuit
- Sawtooth wave generator circuit (2)
