What is the Super Safeway Portable Power System?
Source: InternetPublisher:JFET Keywords: molex power system Molex Updated: 2021/06/14
Various countries are constantly introducing their own policies for the development of industry, which is also conducive to the development of power supplies. Molex’s Woodhead Super Safeway portable power system shows the public a typical case of how to design such a solution to meet extreme situation requirements.
One issue emergency responders face is power system durability. The Woodhead Super Safeway system is made of vulcanized rubber material, which is impact-resistant, non-conductive and corrosion-resistant. It also features a 6-inch aluminum bracket to keep electrical components off the ground, which is why this product complies with UL, CSA, NEC and OSHA construction site portable power system standards. Woodhead cables are also extremely durable, with rubber components in both the cable and system providing the best resistance to chemical exposure and extreme temperatures.
Molex’s Super Safeway system is compact and lightweight, making it easy to carry to the field and small enough to fit into tight spaces without compromising performance. The stackable feature allows multiple cable boxes to be placed onto a single branch box. This way, since the units can be transported and stored in the same configuration, they are extremely easy to use after construction is complete.
As an authorized Molex distributor, Heilind can provide relevant services and support to the market. In addition, Heilind also supplies products from many of the world's top manufacturers, covering 25 different component categories, and pays attention to all market segments and all customers. Constantly seeking a broad product offering to cover all markets. The above is the introduction of Molex's Super Safeway portable power system, but people still need to continue to innovate products.
- How to Make a Soft Latch Circuit
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Single-power supply circuit for ISO122P/ISO124
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Driving circuit that controls LED brightness using PWM signal
- Miniature polarity reversal power supply using MAX1721
- Using CW34603 to form a circuit to change the polarity of the output power supply
- A simple positive and negative power supply circuit
- Dynamic power supply for power amplifier controlled by thyristor
- Constant current charger using light emitting diode as voltage regulator
- DC 12V to AC 100V inverter power supply circuit design
- Laser power circuit
- Dual adjustable power circuit
- EPSON PHOTO 830U printer power circuit
- Power circuit of LBO-522 dual trace oscilloscope
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- Recording level power supply circuit
- Common power circuits and applications 09
- 25Hz ring current power supply circuit
