Third harmonic excitation circuit
Source: InternetPublisher:笑流年 Keywords: excitation harmonics generator Updated: 2020/09/03
There is a third harmonic winding ffl2 inside the third harmonic generator . When the generator is running, the third harmonic
potential
is generated in the Lrj2 winding . This potential is rectified by vc and supplied to the generator excitation winding BQ for excitation. This excitation method
has a simple structure, easy maintenance, and good voltage stabilization effect. Adjusting the potentiometer RP can change the excitation current, thereby changing the generator output voltage.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Design and selection of electric control valve system drive
- The meaning and importance of circuit protection, common types of circuit protection
- Peripheral circuit of automotive motor controller power supply chip
- Using P110C to control 6 DC motors simultaneously
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and manufacture of three-phase motor protection circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- Delay switch made with LM431
- Homemade anti-theft watchdog
- Agricultural small tractor lighting circuit
- Speed regulation by connecting resistors in series in the excitation circuit
- HF4-28-50 diesel engine voltage regulating circuit
- TKL15 type thyristor automatic excitation device circuit b
- TKL15 type thyristor automatic excitation device circuit a
- Reactance shunt excitation circuit
- DC electromagnet strong excitation fast pull-in circuit 4
- DC electromagnet strong excitation fast pull-in circuit one a
- Excitation circuit composed of PMM8713 (3)
- Forward and reverse two-phase excitation circuit of four-phase stepper motor
