Generator longitudinal differential protection circuit with fast saturation converter
Source: InternetPublisher:吃掉星星 Keywords: Protection circuit generator converter Updated: 2020/04/24
In order to improve the sensitivity of the longitudinal differential protection of the generator , it is sometimes necessary to use a fast saturation converter to avoid
the impact of the non-periodic component of the unbalanced current on the protection. The circuit is shown in Figure 7-22. In the figure, KT is a time relay. In order to monitor whether the
secondary circuit is intact and prevent the longitudinal differential protection from malfunctioning due to external short circuit after the secondary circuit
is disconnected, current relay
KA4 is installed.
- A simple magnetic switch circuit sharing
- An automated model railroad layout project using a microcontroller
- Perform surgery on the speaker protection circuit
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Manual automatic air compressor control circuit
- Add one more component to improve the phase failure protection function
- IGBT modules block overcurrent by controlling the gate
- Design and analysis of the principle of automatic power-off switch during power outage
- Light-controlled circuit design and analysis
- Electric vehicle battery charging protection circuit
- Overload protection circuit
- Relay fixed time overcurrent protection circuit a
- Transformer gas protection circuit
- Three-phase motor overcurrent protection circuit
- Overvoltage and overcurrent protection circuit
- Three-phase power supply phase failure protection circuit
- Structure and working principle diagram of various protection circuits e
- Motor overcurrent protection circuit
- Overcurrent protection circuit for generator low voltage starting a
- Small hydropower station control and protection circuit
