Small hydropower station control and protection circuit
Source: InternetPublisher:刘德华河北分华 Keywords: protection circuit power station Updated: 2020/11/22
The circuit is equipped with over-voltage, over-current and overrun protection. The load power supply can come from the power grid
or from small hydropower. There are contactors KMl and KM between the power grid and small hydropower. interlocking.
When the terminal voltage exceeds the specified value, the overvoltage relay KA is closed, and the contactor KM is: released when power is lost, and the load is cut off,
etc.; at the same time, the contactor KMs is powered and closed, and its main contact is connected to the water resistance to prevent overrunning accidents. occur. When the load exceeds
the set value, the overcurrent relay KI is closed, and the KMz is de-energized and released, cutting off the load circuit. At this time, the terminal voltage will inevitably increase,
and the overvoltage relay KA will operate, thereby putting the water resistor into operation to prevent overspeed accidents.
- How to build a simple tachometer using an infrared reflectance sensor
- What is a RADAX motor?
- Introduction to the internal structure of the Delta winding motor
- Perform surgery on the speaker protection circuit
- Manual automatic air compressor control circuit
- Simple phase failure protection circuit composed of intermediate relay
- Simple three-phase motor phase loss protection circuit
- Home wireless burglar alarm circuit
- Homemade anti-theft watchdog
- Vibration anti-theft alarm circuit
- High voltage automatic protection circuit
- Thyristor silicon stack protection circuitb
- Thyristor silicon stack protection circuit a
- Thyristor resistance-capacitance protection circuit c
- Power overload detection box protection circuit
- AC electronic voltage regulator overvoltage protection circuit
- Stabilized power supply overcurrent protection circuit 3b
- Thyristor overcurrent protection circuit one b
- Mains overvoltage protection circuit
- Overcurrent protection circuit for generator low voltage start b
