Generator longitudinal differential protection circuit a
Source: InternetPublisher:红水杯 Keywords: Protection circuit generator BSP circuit breaker Updated: 2020/07/05
Generator longitudinal differential protection is used to protect generator stator windings from phase short circuit. For generators below 800kW, when
the sensitivity of the current quick-break protection does not meet the requirements, longitudinal differential protection can be installed; for generators above 800kW,
longitudinal differential protection should be installed.
The generator longitudinal differential protection circuit is shown in Figure 7-21. In the figure, 1TA and 2TA are current transformers, KA, ~KA.
is the current relay, and KS is the signal relay. KC is the outlet relay, QF is the outlet circuit breaker , and YR is the circuit breaker trip
coil.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- A simple magnetic switch circuit sharing
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Design and production of radio remote control fan stepless speed regulator
- Design and analysis of voice control circuit
- Audio interface protection circuit
- PIC microcontroller controlled remote anti-theft alarm circuit
- Motor forward and reverse control wiring diagram (2)
- Physiotherapy ventilator circuit
- Chicken supplementary light to increase egg production rate circuit
- Double detuned loop frequency discriminator circuit
- Diode square rate detection circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Guest arrival signal recognition circuit
- Power phase sequence display circuit
- Small current generator circuit
- Sawtooth wave generator circuit (2)
