Electronic trip unit circuit
Source: InternetPublisher:张三叔 Keywords: contact coil Updated: 2020/04/19
Both DK-5AD and 5DD control boxes use electronic releases, and their electrical appliances are shown in Figure 6-81. The tripper has overload long
delay, overload short delay, short circuit instantaneous, current limiting, undervoltage and other protection functions. In the figure, TA is a current-to-voltage converter.
rc is the power transformer, S is the shunt button, SB2 is the reset button, SB3 is the test button, C is the zero voltage delay timer
, Q is the undervoltage trip coil , L is the leakage locking contact , and F is the shunt Trip coil , QF is the auxiliary contact of the circuit breaker .
- How to use a microcontroller to control a servo motor?
- Analysis of the working principle of car garage door lights
- Design of an autonomous plant watering system using ATtiny85
- What is a RADAX motor?
- A small improvement on the ordinary refrigerator motor starting circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Design and production of radio remote control fan stepless speed regulator
- Light-controlled circuit design and analysis
- Design and analysis of a four-bit remote control component capable of remote reset
- An experimental model of an infrared radio alarm
- 13 examples of electric drag control circuit diagram
- Homemade disinfectant circuit
- Pyroelectric automatic door control circuit
- Photocell trigger control circuit
- Boiler control circuit
- PLC transmission line automatic reclosing control circuit
- The structure of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor control circuit
- Typical operation display circuit
- Sprinkler control circuit using AC motor
- Voltage servo motor and control circuit
