Spring-operated circuit breaker control, signaling circuit
Source: InternetPublisher:zht24 Keywords: circuit breaker signaling circuit BSP Updated: 2020/04/27
There are many varieties of spring energy storage operating mechanisms, and CT7 type is often used in circuit breakers of iokV and below in factories and enterprises.
The spring energy storage motor of the CT7 type mechanism adopts a single-phase AC and DC series motor with a rated power of 369W.
1 to 4 trip coils can be installed in the operating mechanism. The circuit breaker control and signal circuit
using CT7 type mechanism is shown in Figure 6-69. In the figure, SA is the control switch, which can
be LW5 type or LW2 type; YA is the closing coil of the circuit breaker QF; YR is the tripping coil; sQ is the motor travel
switch (terminal switch); M is the energy storage motor; SB is the button ; Hi is a green indicator light; Hz is a red indicator light.
When the circuit breaker trips in an accident (overcurrent relay KA contact is closed), YR acts.
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Perform surgery on the speaker protection circuit
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and analysis of a four-bit remote control component capable of remote reset
- Design and manufacture of three-phase motor protection circuit
- Magnetic door and window anti-theft alarm
- Guanghua brand anti-theft doorbell electronic lock circuit
- Home wireless burglar alarm circuit
- Homemade short circuit alarm device
- Motor overcurrent protection circuit
- Analysis of rectifier circuit types and principles
- Pulse therapy circuit
- Smoking Cessation Circuit
- Peanut and melon seeds roasting machine circuit
- DC ammeter
- Simple AGC circuit in transistor radio
- ring amplitude modulation circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Wireless microphone circuit
