Two basic circuits of photorelay c
Source: InternetPublisher:Lemontree Keywords: relay BSP Updated: 2020/02/05
Photoelectric relays use photosensitive elements to convert light energy into electrical energy. Commonly used photosensitive components include photoresistors, photodiodes
, phototransistors, photovoltaic cells and photocoupler devices.
Photoelectric relays are divided into two circuits: light-on and dark-on. Light switching means that the relay is closed when the photosensitive element is exposed to light; dark switching means that the relay is closed when
the photosensitive element is not illuminated. Two basic circuits
of
photoelectric relays
- Analysis of the working principle of car garage door lights
- Controlling LEDs with Node-RED in Raspberry Pi
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Build a glove-controlled robotic arm
- What is a RADAX motor?
- DC motor drive circuit composed of L293D
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Design and production of no-load automatic power-off device for household power supply
- Water supply reminder after water outage
- Motor forward and reverse control wiring diagram (2)
- electromagnetic field sensor
- Voice controlled flash LED light circuit diagram
- Self-defense anti-riot circuit
- Particle clogging alarm circuit of wheat seeder
- Greenhouse temperature control circuit
- Diode Balanced Mixer Circuit
- Diode balanced amplitude modulation circuit
- Series crystal oscillator
- Voltage series negative feedback amplifier circuit
