Double tube emergency fluorescent light circuit 4
Source: InternetPublisher:桂花蒸 Keywords: Fluorescent lamp BSP contact Updated: 2020/03/31
Rechargeable emergency fluorescent light circuit for Hitachi. It uses
a switch circuit composed of a multi -contact transfer switch SA and two transistors VT3 and VT4 to complete the working mode selection.
The four working modes (there is no 220V mains power at this time. VTi and VT3 are both cut off) are as follows. ① When SA is set to 1, 6V voltage is added to the oscillation circuit through contacts 1 and 4, windings
W3 and W2 , and the fluorescent lamps Gi and Gz light up.
②When SA is set to 2, contacts Z and 4 are connected, VT4 is conducted, and the light EL is on.
③When SA is set to 4, Gi, G2 and EL will not light up.
④When SA is set to 6, Gi, Gz and EL will all light up.
- Build a Bluetooth-controlled wireless scoreboard
- Measurement and analysis of automatic emergency lighting circuit
- LED Flasher circuit using 2 transistors for LED switching
- Practical sensitive light-controlled switch circuit diagram
- 4-digit incandescent lamp display circuit
- Lighting audio control circuit
- Lighting sound-activated switch circuit using thyristors Part 3
- One of the circuits that control one light in multiple placesb
- Large light emitting diode display circuit
- Temperature control alarm circuit
- Egg warming circuit
- Chicken supplementary light to increase egg production rate circuit
- Greenhouse temperature control circuit
- Farmland irrigation automatic control circuit b
- AC voltmeter
- Double detuned loop frequency discriminator circuit
- Varactor Diode Frequency Modulator
- Audio function generator composed of ICL8038
- Wien bridge oscillator circuit
- Small current generator circuit
