Inverter circuit six
Source: InternetPublisher:newlandmark Keywords: Inverter circuit fluorescent lamp BSP AI Updated: 2021/12/03
The circuit of MYY-787 power outage device is shown in Figure 2-125. It can power two 8W fluorescent lamps ; it can also be used as a signal
light or flashlight. SAi and SA2 (double pole three throw switch) are function switching switches.
The oscillation inverter circuit is composed of transistors VTs, transformer T2, etc. When the mains power is normal, the mains power is stepped down and rectified to
charge the battery GB. At this time, no matter what position the transfer switches SAi and SA3 are in, the electric lamps ELi and ELz and the fluorescent lamps Gi and
G2 will not light up. When the mains power fails, when SAi is turned from the middle to the left, the light ELi - turns on and off as a signal. When
the SAi moves from the center to the right, EL2 lights up and acts as a flashlight. When the switch SA2 is turned from the middle to the left, the fluorescent lamp Gi lights
up and the single tube works; when SA2 is turned from the middle to the right, both Gi and G2 light up and the double tube works. The green light-emitting diode
VL2 is used as a fluorescent lamp working indicator. It’s optional.
- Making a photometer with light measuring function
- A light fence circuit diagram with LDR
- Musical doorbell without buttons
- SC3071 touch step dimming light circuit
- Corridor automatic light-off device
- Lighting audio control circuit
- Simple light-controlled street light circuit (7)
- WT8089 holiday lights ASIC
- Gas and smoke alarm circuits with intermittent alarms
- Touch lighting switch circuit three
- Analysis of rectifier circuit types and principles
- Fish pond oxygenation reminder circuit
- Crop anti-frost circuit
- Agricultural small tractor lighting circuit
- Diode balanced amplitude modulation circuit
- Crabo oscillator circuit
- Double tube emergency fluorescent light circuit 2
- Wiring using broken wire fluorescent lamp b
- tone selector circuit
- Macro JSYZ5-AI gas water heater circuit diagram
