Inverter circuit three
Source: InternetPublisher:宋元浩 Keywords: Inverter circuit BSP transistor Updated: 2021/06/15
It is a self-excited transistor inverter circuit . It can convert 4.5~6V DC power into 220V AC power for
use by 8~40W fluorescent lamps. According to the component parameters shown in Figure 2-121, it can be used for 8W fluorescent lamps.
The function of the diodes VDi and VD2 is to prevent the junction breakdown of the transistors VTi and VT2 from being damaged. Because at
the moment when the lamp is started, the triode changes from conduction to shutdown, the winding connected in series to
the base circuit of the triode will generate a relatively high back pressure between the be
junctions.
The advantage of this circuit is that the load is directly connected in parallel to the oscillation circuit
, so the circuit will stop oscillating when the output load is too heavy, thus protecting
the transistor from damage. The disadvantage is that the efficiency is low, and the output voltage and
oscillation frequency are greatly affected by the power supply.
- LED acceleration and deceleration motion display composed of CD4017
- DCD-1240 multifunctional rechargeable lighting
- Six LED stereo VU display circuit built with IC LM3915
- Design and production of a practical electronic counting device
- "OR" logic element configuration circuit
- Electronic music dimming desk lamp circuit
- Application circuit of CAT3606
- Automotive LED driver circuit diagram using LT3486
- SH-803R holiday lights ASIC
- Touch lighting switch circuit three
- Motor forward and reverse control wiring diagram (2)
- Excellent performance household inverter power supply circuit
- High-efficiency speaker circuit for rural stage
- Chicken supplementary light to increase egg production rate circuit
- DC ammeter
- Diode Balanced Mixer Circuit
- Double detuned loop frequency discriminator circuit
- Diode square rate detection circuit
- Crabo oscillator circuit
- Capacitive feedback oscillator circuit
