One of the light control switch circuits controlled by flashlight
Source: InternetPublisher:宋元浩 Keywords: Switch circuit flashlight light control switch Updated: 2020/11/23
You can use a flashlight to control lights or household appliances on and off within 6-10m. (1) One of the light-controlled switch circuits controlled by
flashlight.
The circuit is shown in Figure 2-102. It uses the phototransistor VTi as the detection element, the three-terminal fixed integrated voltage
regulator A as the working power supply, and the triode VT4 as the switching tube.
When the phototransistor VTi is not illuminated by the flashlight, the relay KA is released. When VTi is exposed to the flashlight for the first time
, KA is engaged and the load is turned on; when the flashlight shines on VTt again, KA is released and the load is cut off.
Adjust the potentiometer RP so that the light control distance is far away and will not be affected by indoor light and cause malfunction. Adjusting the resistance of resistor R3
can change the triggering sensitivity of thyristor V, that is, the sensitivity of the device.
- IR2153 emergency fluorescent lamp circuit diagram
- DCD-1240 multifunctional rechargeable lighting
- LED Signage with RS232 Port Operation Guide
- Musical doorbell without buttons
- Practical sensitive light-controlled switch circuit diagram
- Digital display multi-function thermometer circuit
- Two-way electronic music doorbell circuit
- Photoelectric adjustment circuit
- Touch/wireless remote control dimmer light circuit diagram
- Four color light circuit
- Infrared proximity switch circuit diagram
- Mos tube switch circuit diagram
- FM modulator strong-weak signal switching circuit b
- Touch bistable switch circuit
- Photoelectric control switching circuit composed of photoresistor lamp elements
- Lighting sound and light control switch circuit 4
- One of the light control switch circuits controlled by flashlight
- Light control switch circuit 3 controlled by flashlight
- Simple light control switch circuit
