Street light control circuit 5
Source: InternetPublisher:3228 Keywords: Light control circuit BSP phototransistor Updated: 2021/03/03
This circuit has the advantages of high sensitivity, good temperature stability, and strong anti-interference ability.
Because the brightness changes slowly at dawn or dusk, this will cause the transistor VTz to be in an incomplete conduction or incomplete
cut-off state. If a directly coupled DC amplifier is used, it will be unstable, so a Schmidt circuit is used. The device's response to brightness
can be adjusted via the potentiometer RPi.
The function of the capacitor Ci is to prevent the
controller from malfunctioning when lightning flashes or other light sources instantaneously hit the phototransistor
at night. The delay time is adjusted by RPz. When the value is shown in Figure 2-94, the delay adjustment range is 5-10s.
- Example of LED AC drive circuit
- Measurement and analysis of automatic emergency lighting circuit
- Six LED stereo VU display circuit built with IC LM3915
- Driving circuit for driving light-emitting diodes by IR53HD420
- Infrared remote control dimmer light circuit
- Colorimeter circuit
- One of the circuits that control one light in multiple placesb
- Large light emitting diode display circuit
- Automotive LED driver circuit diagram using LT3486
- Shock resistant soft start constant current LED lighting circuit
- Motor forward and reverse control wiring diagram (2)
- Motor overcurrent protection circuit
- electromagnetic field sensor
- Greenhouse temperature control circuit
- Mixer built with analog multipliers
- Diode Balanced Mixer Circuit
- base amplitude modulation circuit
- collector amplitude modulation circuit
- Wien bridge oscillator circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
