Analysis of the Principle of Kaiyu Intelligent Switching Power Supply Module
Source: InternetPublisher:萌面大虾 Keywords: UC3842 switching power supply circuit Updated: 2024/07/11
Kaiyu brand intelligent switching power supply (also known as universal power supply module). It can be used for the maintenance and replacement of 14-inch to 34-inch color TV, VCD, DVD and satellite receiver switching power supply. The original machine only needs to retain the rectification filter, peak pulse absorption circuit and secondary rectification circuit. It can significantly improve work efficiency during on-site maintenance. The actual object is shown in Figure 1 (omitted).
In order to understand the working principle of the power module, the author disassembled the module and drew its schematic diagram, as shown in Figure 2. From the schematic diagram, it can be seen that the module is very similar to the switching power supply in the color display, that is, it adopts the typical uc3842+field effect tube solution. The difference is that when the blue line is not connected, the error sampling is taken from the primary. uC3842 is a PWM switching power supply integrated controller with excellent performance, wide application and relatively simple structure. Since it has only one output terminal, it is mainly used for switching power supplies controlled at one end.
Debugging method: Connect the module to the circuit as shown in Figure 3, that is, connect the red wire to the original switch tube C pole position, the black wire to the ground, and the blue wire to the optocoupler ④ pin, which can be used for remote control standby (if the original machine is a step-down standby, a 5kΩ~10kΩ adjustable resistor needs to be connected in series). Disconnect all loads in the original circuit and connect a 60w--100w bulb to the output end as a dummy load. After checking that everything is correct, turn on the power, and use a multimeter to monitor the output voltage at the same time, and debug the fine-tuning resistor on the module. Make the output voltage consistent with the original machine, and the other groups of voltages will automatically adapt.
Common troubleshooting methods:
1. When a non-operating fault occurs, check whether the 300V filter and transformer are normal, whether the load is short-circuited, and whether the remote control shutdown related circuits are normal.
2. If overheating, interference or even howling occurs, improve the original machine's absorption circuit. R should be around 39Ω/3W and C should be 470pF~1000PF.
3. In rare cases where the switch transformer does not match the module, the problem can be solved by doubling the main winding of the original transformer. Try not to disassemble the core to avoid damage.
4. The blue line also has a precise voltage stabilization function. Connecting it to the optocoupler will make the working voltage more stable. If it does not meet the requirements, check whether the original voltage stabilization circuit is normal.
- How about the boost converter TPS61299?
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- What kind of circuit is a voltage regulator circuit?
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Driving circuit that controls LED brightness using PWM signal
- LNK304 non-isolated LED light string driver circuit
- Design of electric vehicle charger
- UC3842 Electric Vehicle Charger
- Mc34063 MP3 Switching Charger
- Production of backup power supply for cordless phone
- DC 12V to AC 100V inverter power supply circuit design
- Solar power circuit
- Tongzhou CDVB3188V receiver switching power supply circuit
- Switching power supply circuit using MC44603P
- Output 12V-10A power supply circuit
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- Electric bicycle battery charger made by UC3842
- 50W offline switching power supply circuit
- Charger circuit diagram using UC3842
