How semiconductor holes conduct electricity
Source: InternetPublisher:两手空空 Keywords: semiconductor conductive Updated: 2020/10/17
The continuous development of current science and technology has led to continuous innovation in the semiconductor industry. Semiconductor materials that we are familiar with are commonly used P and N types. Silicon (SI) is doped with the element boron (B). Because B is trivalent, compared to the 4 valence of SI, it lacks one electron. This is missing. The part doped with B is called a hole, and this type of B-doped material is called P-type material. Correspondingly, the element phosphorus (P) is doped. Because phosphorus has a 5-valence, compared to the 4-valence of Si, there is one more electron. This electron comes out alone and becomes a free electron. This type of P doping It's called N-type material.
N-type materials can easily conduct electricity because they have independent free electrons. This is easy for everyone to understand. However, all books tell us that holes in P-type materials can also conduct electricity. This is difficult for us to understand. One of the explanations is that holes The conductive essence of holes is the beating of electrons, but it seems that holes are conducting electricity, so it is called hole conduction. But this explanation still gives us the answer that electrons conduct electricity, but it is easier to accept than having no answer. So how do holes conduct electricity?
During this time, I have been reading books on semiconductors, including conduction band, valence band, and forbidden band. There are many concepts. I endured my scalp and read them patiently. Finally, I understood the concept of hole conductivity that has been bothering me for a long time. But I dare not say that it is right. Let me share with you what I understand first. First, look at some basic concepts in the picture below:
As shown in the figure above, the electrons in the material are divided into three parts according to the energy level. Because this part is a region, it is represented by a "band", and the concept of frequency bands is the same. The more common ones are divided into three levels: valence band, conduction band and forbidden band. The lowest energy is the valence band. When the electrons in the valence band gain energy, they will cross the forbidden band and jump to the conduction band. Note that the forbidden band does not allow electrons to exist. This is determined by quantum theory, that is, the energy levels of electrons can only be distributed in a limited number of energy levels, rather than continuously.
The electrons in the outermost layer of a metal conductor are very active and are free electrons. They gain energy and jump into the conduction band at room temperature, so they can conduct electricity. Insulators have no free electrons, so there are no electrons in the conduction band, so they cannot conduct electricity. For semiconductors, N-type materials doped with 5-valent phosphorus have one more electron, which becomes a free electron and enters the conduction band, so it can conduct electricity. This is easy to understand. What about hole type? Hole type There are no free electrons in the conduction band, so there is no conductive characteristic in the conduction band. This is something that needs special attention.
Since hole-type materials do not have free electrons in the conduction band to conduct electricity, how do holes conduct electricity? So it is definitely not conduction in the conduction band, but the essence of holes is that electrons conduct electricity, but this electron does not come from the electrons in the conduction band, but It comes from electrons in the valence band, which is the core of the problem.
There are a large number of low-energy holes in P-type materials, and there are more valence band electrons around the holes. If these electrons only need to obtain a small amount of energy, and this energy reaches the top of the valence band and the low end of the forbidden band, it will It may jump into the surrounding holes without jumping into the conduction band (it cannot jump over). When the external electric field is added, the hole starts to move, so it becomes a hole conductor. After understanding this, we will understand that P-type materials conduct electrons in the valence band, which is equivalent to hole conduction, and N-type materials conduct electrons in the conduction band, which is electron conductivity. The above are some working principles of semiconductor hole conduction. Engineers need to have an in-depth understanding to avoid detours.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Fabrication of multi-cell lithium battery charging circuit
- Practical and convenient fax machine power supply control circuit
- Recommended circuits for different power on times of LM4911
- Constant current LED lamp driver circuit with soft start and anti-shock
- The constant current source composed of two transistors can drive high power
- LNK304 non-isolated LED light string driver circuit
- Integrated regulated power supply with continuously adjustable output voltage
- Constant current charger using light emitting diode as voltage regulator
- MAX1811 Lithium Battery Charger Production
- Power circuit of STR5412
- EPSON PHOTO 830U printer power circuit
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- Warm current power circuit a
- One of the transistor stabilized current power supply circuits
- Additional power circuit design for USB devices
- Karaoke light controller circuit (1)
- Industrial four-way programmable controller power circuit
- Power circuit for home appliance repair
- Semiconductor component withstand voltage test circuit
