FAN7554 high voltage output flyback power supply
Source: InternetPublisher:Lemontree Keywords: Flyback power supply switching power supply Updated: 2023/11/28
High voltage boost power supply circuit: AC 220V to DC 600V switching power supply circuit
Specification:
Output voltage = 0~600Vdc 0.25A
Switching frequency: 70~100kHz
Design Guidelines:
In DCM mode, the output power is 200 watts
The continuous current mode calculation formula for the degradation of the input rms current is: Irms=Po/Vdc=200/(220*0.9*1.414)≈0.72
If the optimal operating duty cycle is set to D = 0.35, then input the peak current: Ipeak=(Irms/D)*2=(0.72/0.35)*2 ≈4.11
Therefore, the voltage detection voltage level limit from FAN7554 data is 1.5V
- Analysis of the working principle of switching regulator
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Step-down power supply for driving relays
- Single-power supply circuit for ISO122P/ISO124
- Low cost and high performance LED constant current power supply
- A simple positive and negative power supply circuit
- A small and easy-to-make fast charger
- Integrated regulated power supply with continuously adjustable output voltage
- UC3842 Electric Vehicle Charger
- A low-cost, high-reliability battery charger for electric vehicles
- Which one is more suitable: linear power supply, thyristor power supply or switching power supply?
- Switching power supply genuine and fake load inspection
- InnoSwitch-CE switching power supply IC related technical indicators
- Commonly used soft start circuits for switching power supplies
- Working principle diagram of a household switching power supply
- 220V/12V 150W switching power supply circuit diagram
- Working principle of parallel switching power supply
- Switching power supply drive circuit
- Switching power supply control module HK02 circuit-application circuit
- Three-terminal PWM switching power supply-PWR-TOP200 series and applications 01
