24V to 12V switching power converter
Source: InternetPublisher:奥特man123 Keywords: switching power supply transformer Updated: 2023/11/28
When installing 12V electrical appliances (such as instruments, radios, fans, etc.) on 24V diesel vehicles, 12V three-terminal voltage regulators are often used. However, since the voltage drop on the voltage regulator reaches 12V, it consumes a lot of power, has a high temperature, and is easily damaged.
We designed a switching power transformer that can reduce 24V to 12V. The circuit is shown in the figure.
This circuit uses 555 as the pulse oscillator. The ⑤ pin of 555 is connected to a voltage regulator tube to obtain the +6V reference voltage, and the ② pin obtains the sampling voltage from the sampling circuit composed of R7 and R8. When the voltage of pin ② is less than +3V, pin ③ outputs a high level, causing BG3, BG1, and BG2 to saturate and conduct, supplying power to the load. At the same time, the power supply charges C2 through R6, when the potential of pin ⑥⑦ reaches +9V. If pin ② also reaches above +3V, pin ③ outputs low level, the capacitor is discharged through pin ⑦, and switch tubes BG3, BG1, and BG2 are all turned off. When the voltage of the capacitor connected to pin ② is lower than +3V, pin ③ outputs high level again. This is repeated repeatedly to stabilize the output voltage value at the rated output voltage of 12V.
The starting circuit is composed of R1, R2, C1, and D1, so that the circuit provides base current to BG3 when it is first turned on, prompting the switching tubes BG1 and BG2 to conduct, and provides working voltage to 555. When the load is short-circuited, 555 will lose Working voltage, thereby cutting off BG3, BG1, and BG2 to protect the circuit and switching tube.
The inductor L and freewheeling diode D2 can reduce the burden on the switching tube. L can be fully wound with E7 core and Φ1.0mm enameled wire. D2 uses a fast recovery diode or ordinary diode greater than 5A. If you need to output a larger current, the parameters of BG1 are Icm>30A, Vceo>100V, Pcm>150W; the parameters of BG2 are Icm>1.5A, Vceo>100V, Pcm>5W, then the output current can reach 10A. BG1 and BG2 can also be replaced by high-power PNP Darlington tubes.
- Load switch principle, how to judge whether a load switch is good or bad
- TL431 functional pin diagram, DC linear regulated power supply solution based on TL431
- Build a simple buck-boost regulator and test it on a breadboard
- 220V Remote Load Monitor
- Driving circuit of switching power supply field effect tube
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Boost drive circuit composed of RT8450
- A small and easy-to-make fast charger
- Three-terminal fixed voltage stabilized power supply circuit
- Car battery charging circuit diagram
- Comprehensive protection circuit for transformer
- Transformer gas protection circuit
- Lightning protection wiring of transformer connected by Y and yn
- Automatic switching control circuit for two parallel transformers
- Simple buzzer circuit three
- Excitation circuit and synchronous transformer circuit of KZS10 series
- Servo drive circuit with output of 150V and 50A
- 30W feedback transformer switching power supply circuit diagram
