Battery over-discharge protection circuit
Source: InternetPublisher:黄土马家 Keywords: LM311 battery discharge protection Updated: 2023/12/06
The lower limit of the battery voltage is the discharge end voltage. If the discharge continues below this voltage, the performance will be degraded or a fire may occur.
This over-discharge protection circuit does not require a male to connect the power supply. It is powered by a protected battery. Once the discharge end voltage is reached, the battery load and protection circuit are cut off.
The circuit is shown in Figure 1. Use 12V battery as the protection object. It can also be used for battery protection of other voltages. The non-inverting input terminal of comparator IC1 is connected to the 5V reference voltage. This voltage is provided by voltage regulator IC2. The inverting input terminal is connected to the protected battery terminal voltage through the potentiometer VR1. VR1 is used to adjust the protection voltage, here it is adjusted to the discharge termination voltage of the 12V battery, 10V.
When the inching switch SW1 is pressed, the battery supplies power to the protection circuit, the comparator output is "L", and the relay RL1 is powered on. While its contacts are self-protecting, the battery and load are also connected. After releasing SW1, the battery continues to provide power. At the same time, LED1 lights up, indicating that it is in a discharge state.
When the battery discharges to the set termination voltage (10V), the comparator flips over, the relay loses power, and the load and protector are disconnected from the battery to avoid over-discharge.
If the load of the battery is large and the contacts of the relay cannot pass a large current, a contactor can be added. Connect the relay contacts to the contactor coil power. Then use the contactor contacts to connect the load. The circuit is shown in Figure 2.
For example, when using a comparator with low driving capability (such as LM393 or operational amplifier LM358, etc.) that cannot directly drive the relay. A driver stage can be added after the comparator. The driver stage uses a high-power transistor RN2202 with built-in resistor. The circuit is shown in Figure 3. Figure 3 illustrates a 24V battery. At this time, the termination voltage value of VR1 adjustment should be 20V.
If the battery power leads are long, the line resistance will cause a voltage drop. This occurs when the battery voltage approaches the discharge end voltage. The output of the comparator keeps switching "L" and "H", causing the relay to chatter. For this reason, a hysteresis circuit consisting of R3 and R4 is added to the circuit. This malfunction can be avoided.
The above circuit. The coil voltage of the relay or contactor should be consistent with the battery voltage.
- Using Lead-acid Battery as Power Source for Walkman
- What kind of circuit is a voltage regulator circuit?
- Basic connection circuit of signal and power supply composed of ISOll3
- LED rechargeable flashlight circuit diagram
- Switching power supply circuit composition and function introduction of each part
- Low cost and high performance LED constant current power supply
- Charging control circuit made by solar energy
- CNC regulated power supply production
- MIC4680 constant current charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- Excellent performance household inverter power supply circuit
- 24V power supply pure flat display high voltage power supply circuit diagram
- Peak voltage sample and hold circuit
- Three-way DC-DC converter circuit
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- Single phase thyristor slotless nickel plated power circuit
- Transistor stabilized current power supply circuit 2
- Common power circuits and applications 04
- Inverter power circuit
- 25Hz ring current power supply circuit
