SCR AC voltage regulating circuit
Source: InternetPublisher:失踪的猫 Keywords: AC voltage regulator thyristor Updated: 2023/12/05
The circuit below is a thyristor AC voltage regulation circuit. The 220V mains power is converted into three sets of 12V AC voltage through transformer B. One set (U3) serves as the working power supply of the circuit and the signal power supply formed by the sawtooth wave. The other two sets (U2, U4) serves as the synchronous power supply for silicon controlled thyristors SCRl and SCR2 respectively. The sawtooth wave voltage formed by the transistors VTl, VT2, resistors R1~R4, capacitor C1 and other networks is compared with the given signal by the operational amplifier IC1. The square wave signal is output, and then drives VT3 and VT4 through the photoelectric couplers V1 and V2, and triggers the corresponding silicon controlled thyristor SCRl or SCR2 with the synchronization voltage of U2 and U4 to control the voltage of the load RL. Adjust RP to change the given voltage, and the output square wave width of the op amp IC1 will change accordingly, thereby changing the conduction angle of the thyristor. When the RP boom is lowered, the potential of the inverting input terminal of the op amp IC1 decreases, and the output square transition time of the output terminal is advanced and the width is widened. After the isolation coupling of V1 and V2, the conduction time of VT3 and VT4 is advanced, and the thyristor The conduction angles of SC Rl and SCR2 increase, and the voltage obtained on the load RL increases. When the RP boom is raised. The potential of the reverse input terminal of the op amp IC1 increases, and the time for the output terminal to output a square wave is delayed. As the width becomes smaller, the conduction time of VT3 and VT4 moves later, and the conduction angles of thyristors SCRl and SCR2 decrease; the voltage obtained on the load RL decreases, thereby achieving the purpose of voltage regulation.
Working process: During the positive half cycle of the alternating current (the A terminal is positive and the N terminal is negative), the same terminal of the synchronization voltage U2 is positive and the opposite terminal is negative. After rectification by D4 and current limiting by R9, it provides the synchronization voltage to VT3, and the trigger can Silicon controlled SCRt is turned on. During the negative half cycle of the alternating current (the A terminal is negative and the N terminal is positive), the opposite end of the synchronization voltage U4 is positive and the same end is negative. After rectification by D5, R10 provides the synchronization voltage to VT4 after current limiting, triggering SCR2 to turn on. .
- Mobile phone universal charger circuit diagram explanation
- Load switch principle, how to judge whether a load switch is good or bad
- Transformerless Switch Mode Power Supply Circuit Diagram Explanation
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Driving circuit of switching power supply field effect tube
- Basic circuit description of adjustable voltage regulator LM317
- Op amp power supply decoupling bypass measures
- Detailed explanation of 5v charger circuit diagram
- How to use SBR to improve power conversion efficiency
- Charging control circuit made by solar energy
- Capacitor step-down LED drive circuit diagram using thyristor
- Switching power supply circuit composition and detailed explanation of each part (1)
- Multi-channel disconnection alarm circuit
- Simple and practical high-power thyristor trigger circuit diagram
- Maintenance of automobile thyristor voltage regulator
- Using photoelectric thyristor as overvoltage protection circuit
- Simple thyristor temperature automatic control circuit diagram
- SCR AC voltage regulator circuit
- Photodiode circuit in silicon controlled variable frequency synchronous starter
- SCR zero current trigger circuit
