Mobile phone universal charger circuit diagram explanation
Source: InternetPublisher:赔钱虎 Keywords: Charging circuit universal charger Updated: 2025/03/07
Mobile phone universal charger circuit diagram (I)
Working principle: The circuit is mainly composed of oscillation circuit, charging circuit, voltage stabilization protection circuit, etc. Its input voltage is AC220V, 50/60Hz, 40mA, output voltage is DC4.2V, and output current is 150mA~180mA. Before charging, connect the battery to be charged and see if the test indicator on the charger panel is on. If it is on, it means the polarity is correct and you can connect the power supply to charge; otherwise, it means the polarity of the battery and the polarity of the charger output voltage are opposite. At this time, you need to press the polarity conversion switch AN1 (test key).
Mobile phone universal charger circuit diagram (II)
The front stage of the circuit is a common RCC flyback circuit, and the back stage is automatic polarity control.
CT3582 is a chip suitable for universal charging. CT3582 uses a dual-row dip package with a constant current output of 200mA.
End voltage 4.25V, with end voltage fine-tuning device
1 BTN battery negative terminal
2 L3 indicator pin
3 L2 indicator pin
4 L1 indicator pin
5 SEL function selection (connect to VDD for 3-light and 2-light mode, connect to GND for 7-color mode)
6 GND
7 BTP battery positive terminal
8 VCC
- 12v high power battery charging circuit diagram
- How to use LM317 as a switch to turn power load on and off
- LM338 adjustable voltage regulated power supply circuit diagram
- Working principle of LDO voltage regulator, basic circuit diagram of LDO
- TL783 voltage regulator protection circuit diagram
- How to ensure the stable performance of SSD when the voltage is unstable?
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- What kind of circuit is a voltage regulator circuit?
- Single-power supply circuit for ISO122P/ISO124
- Switching power supply circuit composition and function introduction of each part
- MP4 machine battery charging circuit
- Battery charging circuit with reverse connection displayb
- Nickel cadmium battery charging circuit diagram
- New fast charging I charging circuit with discharge
- Constant current charging circuit
- Motorcycle battery clever charging circuit
- Voltage peak incremental automatic charging circuit
- CD4541 cadmium nickel battery automatic charging circuit diagram
- Lithium battery constant current and constant voltage charging circuit diagram
- Charging circuit diagram
