Home >
Audio/Video Circuits >Audio Amplifier Circuits > Single-ended amplifier without magnetic gap output transformer
Source: InternetPublisher:拳制龙 Keywords: single ended amplifier Updated: 2023/11/21
The circuit is shown in the figure. LED×3 provides bias for the power tube (only for field effect power tubes with higher on-voltage VGS, such as MLE20, R413, etc. Power tubes with smaller VG3 are slightly modified according to the actual situation).
The quiescent current of the power tube is between 500mA and 2A (pay attention to heat dissipation). The current of the constant current tube is the same as the quiescent current of the power tube. Since the current directions of the two tubes (in the two sets of coils) are opposite, the magnetic fields generated cancel each other out, thus eliminating the DC magnetization phenomenon.
Another modified circuit is shown in the figure below: the amplifier tube and the constant current tube share a set of biases (the two power tubes need to be strictly matched at this time), making circuit debugging simpler. You can try to disconnect point A from the power supply and connect it to point B. See if the sound quality changes.
The two circuits do not use the filter inductor necessary for a single-ended amplifier circuit. The actual listening signal-to-noise ratio is very high.
It has been one month since the production was completed, and the circuit works very stably.
Sound sweet. The highs and lows are well balanced. This machine has the high sound quality of a single-ended machine and the high signal-to-noise ratio of a push-pull machine, but the output does not require a magnetic gap. Reduce the difficulty of production. The constant current source plays an important role (short-circuit the input terminal or connect it to the signal source. Put your ear close to the speaker to hear a little noise). The price paid is twice the static power consumption of a single-ended machine.
Latest Audio/Video Circuits Circuits
- How to adjust the bass and treble of CXA1005
- Using TDA2822 to do direct coupler output experiment
- LM4766 Dual 40W+40W Power Amplifier
- Homemade multi-sound effects sound system
- Auxiliary audio power amplifier circuit using LM4730/LM4731
- Stereo phono amplifier circuit with bass control composed of LM1877
- LM4902 differential input audio amplifier circuit
- Auxiliary audio power amplifier circuit using LM4732
- Protection circuit and maintenance of household audio power amplifier
- LM4906 Audio Power Amplifier Circuit
Popular Circuits
- LA4461N audio IC circuit
- TDA2030 audio power amplifier circuit diagram
- Voice controlled bird circuit
- Transistor Audio Mixer Circuit Diagram
- 2-tube FM microphone with 3V power supply
- Simulating bird call circuit schematic diagram
- Several good field effect transistor power amplifier circuit diagrams
- Squelch Tuned Audio Switching/Mixing Circuit Diagram
- transistor audio mixer
- High quality melody circuit
