Single tube TV antenna amplifier
Source: InternetPublisher:同住地球村 Keywords: Antenna amplifier Updated: 2024/07/09
The single-tube TV antenna amplifier shown in the figure below uses few components, has low cost, is simple to make, requires no adjustment, and has high performance indicators. It is especially suitable for amateur production by radio enthusiasts.
Principle and production:
The TV signal received by the antenna is coupled to the base of the transistor BG through the capacitor C1, and then output through the collector resonant circuit. The bandwidth of the amplifier is 46-240MHz, the power gain scale Kp>16dB, the noise of the amplifier is small, and it has a strong suppression ability for 10-38MHz. The working voltage of the amplifier is 3V +-0.5V, and the power consumption current is only about 3mA, so it can be powered by two No. 5 batteries. Transistor BG can choose to use ultra-high frequency tubes such as 9018, 3DG80B, and 3DG84B. Capacitors C1-C3 use ceramic capacitors. C4 uses an electrolytic capacitor with low leakage. Coils L1 and L2 use enameled wire with a wire diameter of 0.35mm, which is wound on a round rod with a diameter of 3.5mm. L1 is wound flatly for 9 turns, and L2 is wound flatly for 11 turns. The entire circuit is installed in a shielding box. The input and output lines are all 75Ω cables.
- TA8164P FM Radio
- Design and production of satellite receiver crash recovery circuit
- 1W FM Broadcast Transmitter
- RX3408 FM/FSK 500~20 MHz Receiver
- WE800 FM/FSK 1~0.1 GHz Transmitter
- GPS RF front-end circuit composed of MX2740
- TX4930 FM/FSK 915/868/433 MHz Transmitter
- Rolling code radio transmitter circuit (HSC360/TDA5100)
- T5761/T5760 ASK/FSK 870~868 MHz/928~902 MHz Receiver
- RCV420 4~20mA Precision Current Loop Receiver
- USB communication circuit
- Indoor unit communication circuit
- Two-way communication circuit circuit diagram
- Long distance serial communication circuit
- CAN bus communication circuit
- Wireless transmitter circuit diagram
- Time division multiplexing stereo decoder circuit
- Design of wireless transmitting and receiving circuit based on Bluetooth
- Fiber optic transceiver circuit diagram
- Square wave generation circuit
