One of the protection circuits to prevent short circuit when the motor is started in reverse
Source: InternetPublisher:念念Brown Keywords: Protection circuit motor short circuit BSP Updated: 2020/11/01
During the forward and reverse switching process of the motor
an arc will be generated when the contactor contacts are disconnected. If
the reverse contactor is closed again before the arc is extinguished,
a serious short circuit accident will occur. This requires a protective circuit
to
prevent phase-to-phase short circuits .
The circuit is shown in Figure 4-63. This circuit can ensure
that during forward and reverse operation, the stop button must be pressed first
before proceeding. This means that during the forward and reverse conversion
process, the contactor contacts can be guaranteed to have sufficient
arc extinguishing time, thereby effectively preventing phase short circuits . This is
achieved
through the interlocking of the normally closed auxiliary contacts of the forward and reverse contactors KMi and KMz .
- DIY a simple fire alarm
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Tutorial on making your own remote-controlled robotic arm
- Build a glove-controlled robotic arm
- How can we make the robot move precisely on a predefined path?
- Perform surgery on the speaker protection circuit
- Do-it-yourself trial production of phase failure protection device
- Design and production of no-load automatic power-off device for household power supply
- An experimental model of an infrared radio alarm
- Precious home appliance anti-theft alarm
- Voice controlled flash LED light circuit diagram
- Pulse therapy circuit
- Frequency modulator composed of NE566
- ring amplitude modulation circuit
- Schiller oscillator circuit
- Broadband high frequency power amplifier circuit
- Voltage series negative feedback amplifier circuit
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Small current generator circuit
