Photoelectric phase failure protection circuit
Source: InternetPublisher:spectrum Keywords: Protection circuit photoelectric type phase failure protection BSP Updated: 2020/02/20
It uses three light-emitting diodes VLi-VLs and three photoelectric tubes VTi-VT3 as
detection elements. Use a file to remove the tube caps of VTi~VT3 to expose the die silicon.
When one phase of the power supply is missing, one light-emitting diode does not light up, the transistor VT4 is cut off, and VTs is turned on, causing the relay
KA to close, the contactor to release, and the motor to stop.
- Servo motor pin diagram/working principle/application
- Tutorial for building a remote-controlled Arduino Air-Boat
- Manual automatic air compressor control circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Add one more component to improve the phase failure protection function
- Infrared blocking alarm device
- Magnetic door and window anti-theft alarm
- Bicycle anti-theft alarm
- "Watchdog" anti-theft alarm circuit
- Simple disconnection burglar alarm
- Set timing circuit when power is on
- Smoking Cessation Circuit
- Physiotherapy ventilator circuit
- Poultry warming temperature control circuit
- Proportional frequency discriminator circuit
- Wien bridge oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order band-pass filter circuit
- Wireless microphone circuit
- Guest arrival signal recognition circuit
