Solid state phase failure relay protection circuit a
Source: InternetPublisher:柯南道尔 Keywords: Protection circuit relay BSP semiconductor Updated: 2020/11/06
38. Solid-state phase failure relay is a new device used for three-phase AC phase failure monitoring, protection and control, referred to as SSPORR. It is a semiconductor
module
with 5 terminals , among which terminals 1, 2 and 3 are three-phase monitoring input terminals. The phase sequence is arbitrary,
the current absorbed is very small, and the total of the three terminals does not exceed 1mA; terminals 4 and 5 are switch terminals. The characteristics of this module are: wide operating range, no sparks
and jitter, and large surge current capacity. When the three-phase power supply is normal, terminals 4 and 5 are on; when the phase is missing, terminals 4 and 5 are off, and the protection
and control switches are disconnected. The phase failure protection circuit composed
of solid-state phase failure relay is shown in Figure 4-38.
When one phase of the power supply is missing, the output terminal of SSPORR is cut off, no voltage is output, the contactor KM is released, and the motor stops.
- Tutorial on making your own remote-controlled robotic arm
- Design of an autonomous plant watering system using ATtiny85
- Use your smartphone to turn on/off the power in your home
- Build a glove-controlled robotic arm
- Tutorial for building a remote-controlled Arduino Air-Boat
- What are the challenges in designing a permanent magnet linear generator?
- DC motor drive circuit composed of L293D
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Infrared blocking alarm device
- Magnetic door and window anti-theft alarm
- Voice controlled flash LED light circuit diagram
- Homemade disinfectant circuit
- Poultry warming temperature control circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Amplitude modulation circuit composed of MC1496
- ring amplitude modulation circuit
- Capacitive feedback oscillator circuit
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Various signal generator circuits
