Using NE555 to make a path detector
Source: InternetPublisher:张小哥 Keywords: NE555 path detection Updated: 2024/08/21
This circuit is also a kind of continuity detector, which is suitable for checking the on-off status of the circuit during the installation, debugging and maintenance of electronic equipment. It is easy to make and use.
The 555 integrated circuit is connected into a hysteresis comparison circuit.
A and B are detection probes. Before the detection, A and B are open circuit and suspended, which is equivalent to an open circuit. At this time, pins 2 and 6 of 555 are high level, and pins 3 and 7 output low level, so LED1 lights up, and LED2 does not light up.
Therefore, when A and B are connected to the two ends of the circuit under test, if LED2 lights up, it means there is a connection between A and B, otherwise LED1 lights up.
In general, the equivalent resistance between two points of the measured circuit is ≤30Ω, which is considered as a path, and <30Ω is considered as a block. When the A and B probes touch two points of the measured circuit, if >30Ω, the voltage between pins 2 and 6 of 555 is greater than 1/3 of the power supply voltage, so the output state remains unchanged, and the two LEDs remain unchanged. If <30Ω, the voltage between pins 2 and 6 of 555 is less than 1/3 of the power supply voltage, so the output of pin 3 flips to a high level, making LED2 light up for indication, and at the same time, the internal circuit of pin 7 is open, so that LED1 is cut off and does not light up.
- NE555 long time delay timing circuit
- Monostable trigger driving circuit made of 555 time base circuit
- 555 light control and infrared sensor energy-saving lamp circuit
- 555 pyroelectric infrared sensing and lighting dual control delay energy-saving lamp circuit
- 555 car interior temperature controller circuit
- 555 battery protector circuit with voltage stabilizing charging circuit
- 555 voltage controlled oscillator circuit using Vc terminal to control duty cycle
- 555 pyroelectric infrared sensing timing control socket circuit
- 555 industrial manipulator simple programmable circuit
- 555LCD digital clock hourly self-timer circuit
- ne555 temperature regulation circuit diagram
- Use NE555 to make voice-controlled music lanterns
- Use NE555 to make a two-button touch light switch (1)
- Electric mixer intermittent operation controller circuit
- Water tank automatic water supply control circuit
- Clever use of NE555 as a cycle timer circuit with adjustable on-off time
- Control circuit using NE555 integrated circuit_1
- Circuit diagram of stable and adjustable negative output voltage composed of NE555
- High-efficiency pulse width modulation regulated power supply circuit diagram composed of NE555
- DC voltage polarity converter circuit diagram composed of NE555
