Monostable trigger driving circuit made of 555 time base circuit
Source: InternetPublisher:黄土马家 Keywords: trigger Updated: 2024/08/27
As shown in Figure 4, the 555 time base circuit (IC) is connected in the form of a monostable trigger, and the motor M is connected between the IC output terminal pin 3 and the ground, and the pin 2 is the trigger signal input terminal. Normally, the output signal V=0 at pin 3, and the motor does not rotate. When a negative trigger pulse Vi acts on pin 2, the monostable trigger flips to a temporary stable state, and the output signal Vo=VCC at pin 3, and the motor M rotates. After a certain period of time, the monostable trigger returns to a stable state, Vo=0, and the motor M stops. The characteristic of the monostable trigger driving circuit is that each time the 555 time base circuit is triggered, it drives the load to work for a fixed time, and the working time is equal to the output pulse width D (T=1.1RC) of the monostable trigger.
- Monostable trigger timing circuit
- Monostable trigger driving circuit made of 555 time base circuit
- Using 555 to make an electronic timer hypnotist
- IC555 circuit diagram based on monostable multivibrator
- Several major features of 555 integrated time base circuit
- 555 lantern electronic switch circuit
- 555 color changing electronic corsage circuit
- 555 pyroelectric infrared sensing timing control socket circuit
- 555 fluorescent lamp group centralized rectification and starting circuit
- 555 hours-long adjustable timer circuit
- How to judge whether the thyristor is good or bad by triggering circuit
- Thyristor circuit using integrated flip-flop TD1028
- Three-phase silicon controlled trigger circuit diagram
- T flip-flop circuit structure and its input-output signal waveform
- Emitter coupled flip-flop circuits and applications
- Gantry milling machine trigger schematic circuit
- Astable flip-flop with starter
- Flip-flop driven thyristor circuit
- Demonstration circuit using dual flip-flops
- Power trigger circuit diagram of novel graphic fax machine
