Using 555 to make an electronic timer hypnotist
Source: InternetPublisher:睡不醒的小壮 Keywords: 555 Timing Circuit Updated: 2024/08/21
IC1, R2, RP1, C1, etc. form a monostable circuit, and SB1 is a timing start button. When SB1 is pressed, IC1 is set, and pin 3 is high, and timing starts. The timing time T=1.1(R2+RP1)C1. According to the parameters in the figure, the timing time is roughly 20 minutes to 40 minutes. The high level of pin 3 powers IC2, and IC2 starts working. R3, RP2, C3, etc. form an astable multivibrator. The oscillation frequency of the parameters in the figure is roughly between 0.4Hz and 14Hz, which can be adjusted by RP2. The oscillation frequency is output to the speaker through pin 3 of IC2, making a sound similar to raindrops, which makes people fall asleep. When the timing time of IC1 is up, its pin 3 outputs a low level, IC2 loses power, stops working, and automatically stops.
If a longer timing is required, it can be achieved by replacing RP1 with a larger resistance.
- NE555 makes a pleasant doorbell
- Using NE555 to make an audio signal generator
- 555 light control and infrared sensor energy-saving lamp circuit
- 555 four-digit display capacitance meter circuit
- 555 car interior temperature controller circuit
- 555 wide range adjustable timer circuit
- 555 electronic flute circuit
- 555 controller circuit for automatically changing ten wind speeds
- 555 simple electroacupuncture anesthesia instrument circuit
- 555 simple electronic keyboard circuit (1)
- NE555 time base integrated circuit diagram
- 50% duty cycle 555 circuit
- Self-stopping hypnotic device circuit diagram
- Double-key touch switch circuit diagram using 555 time base circuit
- Pulse width modulation circuit diagram based on 555 base time
- Electric bell sound delayer schematic diagram
- Integrated circuit timer 555 internal structure circuit diagram
- Circuit diagram based on 555 base time astable working mode
- 555 long learning time reminder circuit
- 555 Electronic disinfection circuit using ozone tube
