NE555 makes a pleasant doorbell
Source: InternetPublisher:念念Brown Keywords: Doorbell circuit timing circuit Updated: 2024/10/28
Here is a pleasant doorbell circuit. The 555 timer chip (IC1) in the circuit is connected as a multivibrator. Its output lasts for 7ms when it is low and lasts for 235ms when it is high. When the output of IC1 becomes low, transistor T2 is turned on, activating the buzzer, which sounds and charges capacitor C3. When the output becomes high, the sound intensity of the bell gradually fades. This process is repeated until the timing circuit stops working.
The working process of the timing circuit is as follows: Short press switch S1 causes capacitor C1 to charge rapidly through R1. When the voltage across C1 exceeds the gate threshold voltage of field effect transistor T1, T1 begins to conduct, and this conduction state will continue as long as the charge on C1 makes the voltage greater than this threshold voltage. If the component values used in the circuit are used, the buzzer will beep for about 15 seconds, and its beeping sound is very pleasant. This time is enough for the owner to hear.
- Analysis of the internal structure and working principle of 555 timer
- Voice Control Toy Car
- NE555 makes a pleasant doorbell
- Using NE555 to delay the output of high level circuit
- DC power supply delay circuit diagram illustration
- 555FCNT multi-function power circuit
- 555 rock lantern controller circuit
- 555 TV automatic shutdown controller circuit
- 555 three-state sound and light logic pen circuit
- 555 voice controlled lighting electronic wall clock circuit
- Timing circuit that prohibits restarting
- Automatic periodic switching circuit 4
- Timing circuit composed of TC4013 lamp
- Visual doorbell circuit for deaf people
- Phone doorbell circuit
- Intermittent cycle timing circuit
- High precision, low energy consumption timing circuit
- Timing circuits from minutes to hours
- radio timing circuit
- Multipurpose exposure timing circuit
