One of the heavy load starting thermal relay protection circuits
Source: InternetPublisher:狂妄火龙果 Keywords: Protection circuit relay BSP motor Updated: 2021/02/21
The thermal relay is an overload protection relay. Its two or three heating elements are connected in series to the main circuit of the motor
. When the motor is overloaded, the current flowing through the heating element increases and causes it to heat up. The bimetallic sheet close to the heating element is heated
and bent in a direction. Until the release is pushed open, the coil of the contactor loses power and trips, thereby achieving the purpose of protecting the motor.
The so-called heavy load refers to the load with large inertia moment (such as blower, hoist, air compressor, etc.), and the starting time of the motor
is long (more than 5s). In order to prevent the thermal relay from operating during startup, the following circuit can be used. Figure 4-10 shows a thermal relay protection circuit
with a saturated current transformer . The thermal relay
is connected through the saturated current transformer . The start-up time is 20 to 30 seconds, and can be up to 40 seconds.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Analysis of the working principle of car garage door lights
- The meaning and importance of circuit protection, common types of circuit protection
- Servo motor pin diagram/working principle/application
- DIY an electromagnetic levitation device
- How to make a wheeled self-balancing robot using ultrasonic sensors
- A simple door handle touch alarm circuit
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Bone hyperplasia treatment circuit
- Homemade disinfectant circuit
- Chicken supplementary light to increase egg production rate circuit
- AC voltmeter
- Proportional frequency discriminator circuit
- Amplitude modulation circuit composed of MC1496
- Inductive feedback oscillator circuit
- Three primary color display circuit
- Motorcycle flash light circuit
- Digital stopwatch display circuit
