One of the DC motor armature starting debugging circuits with resistors in series
Source: InternetPublisher:子丑寅卯 Keywords: Electromechanical DC motor Updated: 2021/08/18
The circuit is shown in Figure 3-190. In this circuit, two-stage starting resistors Ri and Rz are connected in series to the armature circuit,
and the starting, speed regulation and shutdown control are realized through the master switch SA. During the starting process, the two time relays KTi and KTz automatically cut off the two
stages of starting resistance. The circuit is equipped with overcurrent protection (KIl) and weak magnetic protection (KI2). KA is the intermediate relay, and KA' is
the undervoltage relay.
When starting, move SA from the "0" position to the "1" position, and the starting resistors Ri and Rz are both connected to the armature circuit. After
a delay (determined by KTi), Ri is short-circuited, and after a delay ( Determined by KT2), and shorted Rz, the motor
enters normal operation at full voltage, and the starting process ends.
If speed reduction is required, the main switch SA can be placed in the "2" or "3" position, and the motor will run with one or
two levels of resistance connected in series to the armature .
- Model rocket launch controller circuit
- Car ice warning circuit sharing
- What is a RADAX motor?
- Manual automatic air compressor control circuit
- Simple phase failure protection circuit composed of intermediate relay
- One-way rotation circuit of motor controlled by contactor
- Add one more component to improve the phase failure protection function
- Design and analysis of wire control circuit
- Do-it-yourself trial production of phase failure protection device
- Bicycle anti-theft alarm
- Differential amplifier emitter negative feedback gain control circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Micro remote control receiving and control circuit
- fire smoke control circuit
- Car window control circuit
- Assembly line outage monitoring circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- Photoelectric detection output control circuit
- Steam iron temperature detection control circuit
- Small power electric heater temperature detection control circuit
