黄土马家
FREMONT (MAXREFDES6#): 16-bit, high-precision, 0 to 100mV input, isolated analog front end (AFE)
The compact Fremont (MAXREFDES6#) subsystem reference design ( Figure 1 ) utilizes a high-precision, 16-bit analog front end (AFE) to accurately measure 0 to 100mV low-voltage single-ended analog signals and features an isolated data path. The design takes advantage of the following devices: ultra-precision, low-noise buffer ( MAX9632 ); high-precision ADC ( MAX11100 ); ultra-precision 4.096V voltage reference ( MAX6126 ); 600VRMS single-chip data isolator ( MAX14850 ); low dropout voltage (LDO) voltage regulators that provide regulated +6V, +5V, and -5V supplies ( MAX1659 and MAX1735 ). This unique AFE solution is ideal for many applications requiring low voltage input, high impedance, and high-precision analog-to-digital conversion. Smart factories, industrial and medical applications use an increasing number of sensors in various configurations. Although low-voltage sensors provide critical data, they also require/generate high signal-to-noise ratio signals, rendering many discrete and integrated analog-to-digital converters (ADCs) inadequate for such applications.
Fremont subsystem design block diagram
Figure 1. Fremont subsystem design block diagram.
characteristic
application
  • High-precision analog input
  • High impedance
  • 0 to 100mV input range
  • Isolate data paths
  • Small size printed circuit board (PCB)
  • Device driver
  • C language source code
  • Pmod™ Compatible Specifications
  • Low voltage output sensor
  • process control
  • medical
Competitive Advantage
  • Unique single-ended structure
  • Optimum board size
  • Magnetic interference resistant data path isolation
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-01 13:24:27
