qoistoochee128
face recognition
This solution provides a higher level of security, supports dual CMOS cameras and TFT LCD display devices, and can add 3D facial recognition. It can also transmit all attendance data to the background for recording via Ethernet. The main features of Nuvoton N329 series are the high-performance and low-cost 32-bit ARM® ARM9EJ-S core, which can run at 200MHz ~ 300MHz and supports network interfaces, high-speed USB interfaces, dual CMOS cameras and TFT LCD displays equipment. More importantly, the N329 series has stacked 8M Byte to 64 M bytes DDR memory space, which not only facilitates customers to make circuit boards from 2-layer boards to 4-layer boards, but also makes it easy for customers to pass EMI and EMC certifications. The N329 series basically integrates the face recognition function into an IC, which not only saves costs but also allows the product to be completed with a smaller PCB. Based on the above characteristics, the N329 series is a very cost-effective solution in face recognition applications.
Blockdiagram
Search Datasheet?
Forum More
Update:2025-08-09 06:51:34
