Lemontree
GNSS expansion board based on Teseo-LIV3F module for STM32 Nucleo
X-NUCLEO-GNSS1A1
The X-NUCLEO-GNSS1A1 expansion board is based on the Teseo-LIV3F tiny GNSS module.
It represents an affordable, easy-to-use, global navigation satellite system (GNSS) module, embedding a TeseoIII single die standalone positioning receiver IC, usable in different configurations in your STM32 Nucleo project.
The Teseo-LIV3F is a compact (9.7x10.1 mm) module that provides superior accuracy thanks to the on-board 26 MHz temperature compensated crystal oscillator (TCXO) and a reduced time-to-first fix (TTFF) with its dedicated 32 KHz real-time clock (RTC) oscillator.
The Teseo-LIV3F module runs the GNSS firmware (X-CUBE-GNSS1) to perform all GNSS operations including acquisition, tracking, navigation and data output without external memory support.
The X-NUCLEO-GNSS1A1 expansion board is compatible with the Arduino™ UNO R3 connector and the ST morpho connector, so it can be plugged to the STM32 Nucleo development board and stacked with additional STM32 Nucleo expansion boards.
Main features
  • Operating supply voltage: 3.3 - 5 V
  • Ambient temperature: -40/+85 °C
  • Sensitivity: -162 dBm indoor (tracking mode)
  • Interfaces:
    • a UART port
    • an I²C port
    • Configurable digital I/O timepulse
    • EXTINT input for wakeup
  • NMEA protocol
  • Assisted GNSS:
    • Predictive autonomous
    • Predictive server-based
    • Real-time server-based
  • Compatible with STM32 Nucleo boards
  • Compatible with the Arduino™ UNO R3 connector
  • LNA and SAW filter on the RF path
  • SMA female antenna connector
  • Battery holder
  • RoHS and WEEE compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-12 16:30:48
