elleny
ST25R3916 based NFC reader expansion board for STM32 and STM8 Nucleos
X-NUCLEO-NFC06A1
The X-NUCLEO-NFC06A1 NFC card reader expansion board is based on the ST25R3916 device.
The expansion board is configured to support ISO14443A/B, ISO15693, FeliCa™ and AP2P communication.
The ST25R3916 manages frame coding and decoding in reader mode for standard applications, such as NFC, proximity and vicinity HF RFID standards. It supports ISO/IEC 14443 Type A and B, ISO/IEC 15693 (single subcarrier only) and ISO/IEC 18092 communication protocols as well as the detection, reading and writing of NFC Forum Type 1, 2, 3, 4 and 5 tags.
The on-board low power capacitive sensor performs ultra-low power wake-up without switching the reader field on and traditional inductive wake-up to select amplitude or phase measurement.
The automatic antenna tuning (AAT) technology enables operation close to metallic parts and/or in changing environments.
Main features
  • On-board NFC card reader IC: ST25R3916
  • 47 mm x 34 mm, four turns, 13.56 MHz inductive antenna etched on PCB and associated tuning circuit
  • Six general purpose LEDs
  • ISO 18092 passive and active initiator, ISO 18092 passive and active target
  • NFC-A and NFC-F card emulation
  • ISO 14443A and ISO14443B
  • ISO 15693
  • FeliCa™
  • Up to 1.7 W output power with differential antenna
  • Possibility of driving two antennas in single ended configuration
  • Inductive and capacitive wake-up
  • Automatic antenna tuning system
  • Transparent and Stream modes to implement MIFARE™ Classic compliant or other custom protocols
  • Equipped with Arduino UNO R3 connector
  • Free comprehensive development firmware library compatible with STM32Cube and samples for ST25R3916
  • Scalable solution for multiple board cascade
  • FCC certified
  • RoHS and WEEE compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 15:02:19
  • Asynchronous or synchronous communication?
  • GPS, ucOS+ucGUI+STM32 (transferred)
  • High voltage power quick connect terminal
  • TI Power Supply Design Tips 8
  • SQL CE 2.0 uses RDA to connect to SQL Server. Problems occurred. Waiting online
  • CCS5.5 CMD file summary
