石榴姐
Industrial digital output expansion board based on ISO8200AQ, suitable for STM32 Nucleo
X-NUCLEUS-OUT02A1
The X-NUCLEO-OUT02A1 industrial digital output expansion board for STM32 Nucleo is based on the ISO8200AQ galvanic isolated octal high-side smart power solid state-relay.
It provides an affordable and easy-to-use solution for the development of 8-channel digital output modules, letting you easily evaluate the ISO8200AQ communication and industrial load driving features.
The X-NUCLEO-OUT02A1 can be connected to a NUCLEO-F401RE or NUCLEO-F334R8 development board via Arduino™ UNO R3 connectors.
You can also evaluate the 16-channel digital output modules by connecting two X-NUCLEO-OUT02A1 expansion boards and activating the daisy chaining feature.
The X-NUCLEO-OUT02A1 interfaces with the STM32 controller via SPI and GPIO pins and is compatible with the Arduino™ UNO R3 (default configuration) and ST morpho (optional, not mounted) connectors.
Industrial PLC functionality with 8 inputs and 16 outputs can be added with the X-NUCLEO-PLC01A1 expansion board.
Main features
  • Based on the ISO8200AQ whose main characteristics are:
    • Embedded 4kV galvanic isolation
    • Radio frequency communication between the logic and process sides for maximum noise immunity
    • Very low power dissipation (RON(MAX) = 220 mΩ)
    • Fast decay for inductive loads
    • 20 MHz SPI I/F on logic side
    • VCC power good diagnostics
    • Overload and overheating protections with thermal shutdown and diagnostics
    • QFN-32L (9x11x1 mm) package
  • 10.5 to 33 V operating voltage range
  • Green LED (x8) for output on/off status
  • Red LED for process supply power good fault
  • Red LED for overload and overheating
  • Supply reverse polarity protection
  • EMC compliance according to IEC61000-4-2, IEC61000-4-3, IEC61000-4-5
  • Compatible with STM32 Nucleo boards
  • Equipped with Arduino™ UNO R3 connectors
  • CE certified
  • RoHS and China RoHS compliant
  • WEEE compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-18 15:33:53
  • Calling custom functions in the driver
  • Ask an expert
  • R&S Automotive Test and Measurement Solutions
  • Fixed-point arithmetic operations of TMS320
  • Current status of research on porting uclinux to niosII
  • STM32+AD9832
