newlandmark
20 W + 20 W dual BTL Class D audio amplifier demonstration board based on TDA7491HV
STEVAL-CCA042V1
The STEVAL-CCA042V1 demonstration board is designed for the TDA7491HV high-power dual BTL class-D audio amplifier.
Thanks to its high efficiency, the device assembled in the PSSO36 (slug-down) package is capable of dissipating heat without a heatsink.
Jumpers on the board allow configuration of the amplifier to verify all the features as single-ended or differential inputs, fixed gain settings.
Microswitches are also provided to enable the standby and mute functions
Main features
  • 20 W +20 W continuous output power at THD = 10%, RL = 8 Ω, VCC = 18 V
  • 9.5 W + 9.5 W continuous output power at THD = 10%, RL = 8 Ω, VCC = 12 V
  • Wide-range single-supply operation (5 - 18 V)
  • High efficiency (η = 90%)
  • Four selectable, fixed gain settings (20 dB, 26 dB, 30 dB and 32 dB)
  • Differential inputs to minimize common-mode noise
  • Filterless operation
  • Standby and mute features
  • Short-circuit and thermal overload protections
  • Externally synchronizable
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 14:52:37
