aytwartoofyoroo
VN7008AJ Evaluation Board
EV-VN7008AJ
This board provides you an easy way to connect STMicroelectronics®VIPower®M0-7 technology into your existing system.
Main features
  • Simple single IC application board dedicated for VN7008AJ
  • Provides electrical connectivity and thermal heat-sinking for easy prototyping
  • General device features
    • Single channel smart high-side driver with CurrentSense analog feedback
    • Very low standby current
    • Compatible with 3 V and 5 V CMOS outputs
  • Diagnostic functions
    • Dedicated high precision proportional load current sense
    • Overload and short to ground (power limitation) indication
    • Thermal shutdown indication
    • OFF-state open-load detection
    • Output short to VCC detection
    • Sense enable/ disable
  • Protections
    • Undervoltage shutdown
    • Overvoltage clamp
    • Load current limitation
    • Self limiting of fast thermal transients
    • Configurable latch-off on overtemperature or power limitation with dedicated fault reset pin
    • Loss of ground and loss of VCC
    • Reverse battery with external components
    • Electrostatic discharge protection
Search Datasheet?
Forum More
Update:2025-08-07 12:50:31
  • Common cathode digital tube
  • Hardware configuration of MSP430's USART
  • Bluetooth low energy data transfer rate
  • Are there no spring outings or anything like that recently?
  • Touch screen selection
  • 4*4*4 Colorful Led Detailed Production Flowchart
