aytwartoofyoroo
EVAL-L99MOD51XP Evaluation Board
EVAL-L99MOD51XP
The EVAL-L99MOD5xXP evaluation kit consists in a motherboard and a daughterboard on which the L99MOD5xXP device is assembled. Both of these evaluation boards provide electronic control modules with enhanced power management functionalities including a standby mode.
The motherboard, based on the SPC56 microcontroller, provides the logic section for driving and monitoring the L99MOD5xXP device assembled on the daughterboard.
With the aim of facilitating the use and configuration of the board, ST provides a dedicated user-friendly software with a graphic user interface (GUI) which can be downloaded from STMicroelectronics's website.
The GUI enables the user to set the L99MOD5xXP parameters and get real time information from the device, such as registers status, analog current sense, fault flags and much more.
Main features
  • MOSFET and diode reverse battery protection network
  • Possibility of powering at 12 V through daughterboard connector
  • Half-bridge and high-side outputs available depending on the specific device
Search Datasheet?
Forum More
Update:2025-08-07 09:19:49
  • Touch screen sampling problem (after each startup, the sampling value of the same point varies greatly)
  • Some things to know about PCB design
  • Can 430 be connected to 8255?
  • AVR timer compare mode problem
  • TF card receives design data
  • How does a mixed signal become a DC signal?
