MartinFowler
ISM330DLC adapter board, standard DIL24 socket
STEVAL-MKI182V2
The STEVAL-MKI182V2 is an adapter board designed to facilitate the evaluation of MEMS devices in the ISM330DLC product family. The board offers an effective solution for fast system prototyping and device evaluation directly within the user’s own application.
The STEVAL-MKI182V2 can be plugged into a standard DIL 24 socket. The adapter provides the complete ISM330DLC pin-out and comes ready-to-use with the required decoupling capacitors on the VDD power supply line.
This adapter is supported by the STEVAL-MKI109V2 and STEVAL-MKI109V3 motherboards, which include a high performance 32-bit microcontroller functioning as a bridge between the sensor and a PC, on which it is possible to use the downloadable graphical user interface (Unico GUI), or dedicated software routines for customized applications.
Main features
  • Complete ISM330DLC pinout for a standard DIL 24 socket
  • Fully compatible with STEVAL-MKI109V3 motherboard
  • Changing the resistor settings is also compatible with the STEVAL-MKI109V2 motherboard
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-21 23:23:49
  • Ask about embedded systems?
  • As title
  • STM32F407IGT6 has burned out 9 chips
  • Smooth configuration of bq4050
  • Tell us now, have you received the gift you wanted most on Valentine’s Day?
  • Ask: About STM32 timer clock problem...
