supremeOne
ASM330LHH adapter board, standard DIL24 socket
STEVAL-MKI193V1
The STEVAL-MKI193V1 is an adapter board designed to facilitate the evaluation of MEMS devices in the ASM330LHH product family. The board offers an effective solution for fast system prototyping and device evaluation directly within the user’s own application.
The STEVAL-MKI193V1 can be plugged into a standard DIL 24 socket. The adapter provides the complete ASM330LHH pin-out and comes ready-to-use with the required decoupling capacitors on the VDD power supply line.
This adapter is supported by the STEVAL-MKI109V3 motherboard with high performance 32-bit microcontroller functioning as a bridge between the sensor and a PC, on which it is possible to use the downloadable graphical user interface (Unico GUI), or dedicated software routines for customized applications.
Main features
  • Complete ASM330LHH pinout for a standard DIL 24 socket
  • Fully compatible with STEVAL-MKI109V3 motherboards
  • Changing the resistor settings is also compatible with the STEVAL-MKI109V2 motherboard
  • WEEE compliant
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 04:21:28
