aerobotics
For STM32 Nucleo, LED driver expansion board based on LED1202 device
X-NUCLEO-LED12A1
The X-NUCLEO-LED12A1 LED driver expansion board for STM32 Nucleo features four LED1202 devices that can drive up to 48 LEDs.
[X-NUCLEO-LED12A1 IMAGE]
The LED1202 is a 12-channel low quiescent current LED driver, which guarantees 5 V output driving capability. Each channel is able to provide up to 20 mA with a headroom voltage of 350 mV (typ.) only.
The output current can be adjusted separately for each channel through an 8-bit analog and 12-bit digital dimming control.
The X-NUCLEO-LED12A1 expansion board comes with an additional LED panel board that houses two LEDs matrices: a 6x8 white LED matrix and a 4x4 RGB matrix.
LED matrices can be supplied via an external power supply connected to J13 connector and by selecting the right path through J15 jumper to reach the maximum luminosity available.
所有功能
Four LED1202 devices driving up to 48 LEDs
One double row pin array connector for external LED panel connection
One jumper selector for internal/external LED power supply
One panel with 48 white LEDs/16 RGB LEDs included
Arduino UNO R3 connectors
Free comprehensive development firmware library compatible with STM32Cube
Scalable solution for multiple board stack
RoHS and WEEE compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 02:36:33
