aytwartoofyoroo
VL53L3CX-SATEL: Breakout board with VL53L3CX multi-object detection ToF ranging sensor for easy integration into customer equipment
VL53L3CX-SATEL
The VL53L3CX-SATEL breakout boards can be used for easy integration into customer devices.
Thanks to the voltage regulator and level shifters, the VL53L3CX breakout boards can be used in any application with a 2.8 V to 5 V supply.
The PCB section supporting the VL53L3CX module is perforated so that developers can break off the mini PCB for use in a 2.8 V supply application using flying leads. This makes it easier to integrate the VL53L3CX-SATEL breakout boards into development and evaluation devices due to their small form factor.
Main features
  • VL53L3CX Time-of-Flight (ToF) ranging sensor with multi target detection
  • Regulator: 5 to 2.8 V range input voltage (output voltage: 2.8 V)
  • VL53L3CX signal interface level shifter
  • True distance measurement independent of target size and reflectance
  • Divisible board enabling use as mini PCB breakout board, easy to integrate in customer device
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 00:55:40
