sigma
EVL80WLED-STCH03: STCH03-based 80W-1A primary-side current loop controlled LED driver for street lighting
EVL80WLED-STCH03
The EVL80WLED-STCH03 demonstration board implements a wide range 80 W - LED driver for street lighting applications with a primary current sensing control loop.
The LED driver is a fixed current source with a very fast start-up time, protections to short-circuit and to open load. The board is optimized to supply an LED string load in the range from 40 V to 80V with a fixed 1 A current source with a very low current ripple.
Due to current primary side STCH03 control loop, the output stage is composed of a simple diode rectification and the output capacitor.
Form factor is compatible with street lighting application.
At full load the efficiency is above the 90% at nominal voltages and remains very close to this value till half the load.
Output short-circuit and no-load protections are auto-restart for a safe operation in lighting environment.
Low input power is there at no-load conditions.
Main features
  • Input voltage: Vin: 90 - 265 Vrms, f: 45-66 Hz
  • LED string range: [40 -80] V / 1A
  • Output current ripple
  • Fast startup:
  • High power factor, low THD (
  • No-load:
  • Average Full load efficiency: >90%
  • Short-circuit protection with auto-restart
  • LED string open with auto-restart
  • Acc. to EN61000-3-2 Class-C or JEITA-MITI Class-C
  • EMI: Acc. To EN55022 class B - conducted emissions
  • Safety: Acc. to EN60065C
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-11 21:46:02
