toothache
IO-Link industrial modular sensor board based on L6362A
STEVAL-IDP003V1
The STEVAL-IDP003V1 kit includes the STEVAL-IDP003V1D evaluation board based on the L6362A IO-Link device transceiver and the STM32L071CZ microcontroller for data processing, and the following sensor daughter boards: temperature sensor STTS751 hosted on the STEVAL-IDP003V1T, MEMS sensor IIS2DH hosted on the STEVAL-IDP003V1TV, MEMS sensor IIS328DQ hosted on the STEVAL-IDP003V1A and proximity sensor VL6180X hosted on the STEVAL-IDP003V1P.
The evaluation board is equipped with an industrial M12 connector (required by the standard) for connection with a single master IC using a 20-meter cable. The wire is a normal three-pole wire: one for IO-Link data, one for the L+ line (positive supply voltage pole) and one for the L- line (negative supply voltage pole).
The layout is designed to meet IEC61000-4-2/4 and EN60947 requirements for the industrial sector.
Main features
  • Main supply voltage: 32 V maximum
  • STM32L071CZ microcontroller
  • IO-Link PHY using the L6362A device for data communication with host unit
  • DC-DC converter and linear regulator on board
  • Integrated reverse polarity protection on L6362A ICs
  • Multi-sensor connection
  • 400 kHz I²C communication
  • PCB designed to accept real industrial sensors (8 mm x 70 mm, with 0.8 mm thickness)
  • Designed to meet IEC industrial standard requirements
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 15:19:18
  • Big news, E coins can be exchanged for gift cards!!!
  • Google Glass unboxing review: More sophisticated than expected
  • Design of Liquid Level Detection System in Stereolithography
  • Principle and Fault Examples of Automobile CAN Data Transmission System
  • Looking for part-time job
  • GPRS module to send text files?
