aerobotics
IO-Link master multi-port evaluation board based on L6360
STEVAL-IDP004V2
The STEVAL-IDP004V2 evaluation board embeds the STM32F205RB microcontroller and four separate L6360 ICs.
Communication with the ICs is implemented via I²C in master mode and is managed by the STM32F205RB MCU; each L6360 has its own address and shares the bus with the other devices.
The STEVAL-IDP004V2 is developed to create a multi-port master based on serial asynchronous communication to support the IO-Link protocol.
Each node is equipped with an industrial M12 connector (as recommended by the standard) for connection with a single slave node using a cable (max. length 20 meters). The wire is a normal three-pole: one for the IO-Link bus, one for the L+ line (positive supply voltage pole) and one for the L- line (negative supply voltage pole).
The STEVAL-IDP004V2 board also includes RS-485 bus, CAN bus and USB hardware interfaces.
The layout is designed to meet the requirements for IEC61000-4-2/4/5 for industrial segment.
Main features
  • Master IO-Link stack embedded with read out protection
  • Limitation of time of use (10000 minutes)
  • Fully compatible with all IO-Link devices
  • Main supply voltage 32 V maximum
  • 4 L6360 IO-Link master transceiver ICs
  • RS-485 serial interface
  • CAN serial interface
  • USB interface
  • DC-DC converter
  • On-board reverse polarity protection
  • Designed to meet IEC requirement for industrial standards
  • RoHS and WEEE compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 08:11:53
