qoistoochee128
High-brightness LED array driver with diagnostics for automotive applications based on STAP08DP05 and STM8AF
STEVAL-ILL058V1
The STEVAL-ILL058V1 evaluation board is a high brightness LED array driver application with diagnostics based on the automotive grade, low voltage, 8-bit constant current LED sink driver STAP08DP05 from STMicroelectronics.
The LED driver is configured and controlled through an 8-bit automotive grade STM8A microcontroller via SPI interface.
An automotive grade A5974D DC-DC converter provides the voltages and power for the overall functioning of the board.
Main features
  • 6 - 24 V DC power supply with reverse voltage protection, short-circuit protection and standard DC jack input
  • Backward/forward transition switch and reset switch
  • SWIM connector to program microcontroller and for debugging purposes
  • Connector for LIN development and evaluation
  • Brightness control potentiometer
  • Speed control potentiometer
  • 40 white LEDs (PLCC 4)
  • 8 jumpers to simulate open-circuit errors
  • 4 jumpers to simulate short-circuit errors
  • Slot for USB-to-UART daughterboard
  • Demonstrates pre-configured patterns (dot-sequence, backlighting, alphanumeric text etc.) in stand-alone mode
  • Demonstrates basic mode or frame programming mode with GUI SW
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 11:13:25
