qoistoochee128
STLED524 Evaluation Kit (5 x 24 Matrix LED Display Driver)
STEVAL-LLL001V1
The STEVAL-LLL001V1 board is designed to demonstrate the features of the STLED524 intelligent matrix LED display driver with a 5 x 24 matrix of SMD white LEDs incorporated on the board.
Two boards can also be joined using the on-board connectors to drive a 10 x 24 LED matrix.
The board is driven by the USB control board for interface with the graphical user interface (GUI), but there is also an SPI interface connector on the STEVAL-LLL001V1 which can be used for customized control.
Main features
  • Operating input voltage from 2.7 V to 5.5 V
  • Drives 5 x 24 LED matrix
  • Luminance separately adjustable for each LED by internal registers in 255 steps
  • Internal registers capable of storing two patterns
  • 4-way scroll function with a possibility to lock column data
  • 255-step PWM dimming
  • SPI interface
  • Integrated step-up converter with adjustable output voltage
  • Integrated LDO with 3.1 V output at 80 mA
  • CSP 56 bumps 0.4 mm pitch 3.4 x 3.0 mm
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-12 19:11:44
